dmetalmiki
- 2,027
- London England
Safe cutoff switch
All my trucks have the cut off isolator switches on the posative + power side of the battery (ies).
The logigical reasoning here is that. (a) On these trucks (not chevies dodges some fords etc WITH ECUs etc Which would fail "memory in the computer update running performance settings. RADIO memories cd s etc etc etc)
OUR trucks as is are strictly bare bones "as is" no frills and or electronics.
(b) With the isolater on the + ve side and CLOSE to the battery terminal there is no chance of an accessory short circuit. (with in my case) Items like siren kit, radio, lights, C.B.s Phone chargers etc etc. ALL 12 VOLT items running from the " last battery". (yes I know inverters..Mine use a LOT of current. (12volt winches in back for example)). ONLY for hauling Army moto bikes up.
Scenario. (simply explained). ANY of the 12 volt accessories which were grounded by accident would blow. Because THEY would be acting the -VE (negative for 24 VOLTS , closing the ground for the FIRST battery. For example. IF you forget to turn ON a Negative Isolator switch.." BOOM" the accesory FRIES! (goes up in smoke).
The posative on the first battery is closed to 24 volts through the second batteries power (accessory) to GROUND.
IF you have no 12volt accessories ok really. But it is GOOD principal to isolate the " power" +. then NO current flows. ((exept for the 12 Volt accessories IF used from the last battery))
To quallify, with an ISOLATOR switched OFF Via Negative TERMINALS current FLOWS through all wires till switched on at souce, ( switches for lights heater etc)and they EARTH to work via exit wires from those switches.
IT naturally follows that ANY wire accidently earthed (grounded) as when you might be carrying out maintnance or fitting something BEFORE the SWITCHES (that operate things) will be live and BURN. (current flowing through posatives looking for resistance WORK ( from switches to heaters radios whatever) to grounds)
long winded, but takes thinking and studying over if not a "sparky" (which I am Not)
9.2.2.3.1
A switch for breaking the electrical circuits shall be
placed as close to the battery as practicable. If a
single pole switch is used it shall be placed in the
supply lead and not in the earth lead.placed as close to the battery as practicable. If a
