- 463
- 9
- 0
- Detroit, michigan
I have a M923A1 is it a 1986, NHC250. When I got it a couple months ago, the first thing I did was drain the fuel tank, reached in and dried it as much as possible and let it set open for the day, then added lucas fuel additive for diesels and put in 25 gallons of fuel. I changed all the filters, removed the fuel hand pump and replaced the o ring so it had a good seat. After all fluids and filters were changed and fresh fuel was put in I started her up. After hand pumping fuel up I fired her off. The first time she cranked for maybe 8 seconds and fired and stayed running. I checked the gauges and oil pressure was good. After putting about 75 miles on her with no issues, I stopped at a light and when I pushed down on the fuel pedal she acted like she was down a cylinder and was pulling very slow and building power and RPM
very slowly. I let off and on a few times and she started pulling again normal.
This has happened a few times now. It's just like she is down a cylinder. Do you think a injector might be bad. The truck has about a hundred miles on it since all filters and fluids have been changed. Ideas of what to do or is there a way to check for a bad injector that is not always bad? you ideas of what it could be?
