Injection pump replacement
tommyd
Happy Easter all,
My pump is done. Should I replace anything else while its in the shop? Would it be a good time to replace injectors and glow plugs? Bought it with 22k and now has 47k. Lastly, where would be the best place to get parts?
Thanks in advance!
chevyCUCV
Massachusetts
Im planning on doing headgaskets, ip, injectors, and front main seal.
That way i will do one tear down and major repair, and hopefully be good for a while.
tommyd
A local shop wants 800 to refurbish the pump. Not going to happen! Anyone have a good reliable source for one? I seen eBay has a few, but what one do I need for a 85 1009? I'm not nearly on the mechanical level as most here. Should have spent more time around the motor pool!
Semper fi,
Tommy
Recovry4x4
LLM/Member 785
1,808
GA Mountains
The problem you may have is getting a pump that you purchase, installed. Kinda like buying a steak at the grocery store and taking it to Longhorns and having is cooked. If there is a problem with the pump, who pays the labor to remove it for service. If the installer breaks it, who pays to replace it? I'd think long and hard before having parts you buy, installed by others.
det rebel
east texas
the pumps do take a little mechanical skill to replace but it can be done by just about anyone price of pump = my local shop can do it from 400 to 600 for just the labor now for finding a pumpthat might be difficult unless there is a scrap yard that buys military trucks close by
antennaclimber
949
State College, PA
chevyCUCV
Massachusetts
I got two ip's off blown engine's i bought on craigslist.
They were both recent replacements and very clean compared to the one in my truck.
Spent 100 for one engine, and got all the other parts that were left on it too
Great way to save money and end up with lots of extra parts that many people still need.
By shop do you mean mechanic?? If so you are going to have to spend lots, if its in your shop it is just more time that you will have to put in.
tommyd
The mechanic is excellent and has no problem with me buyin the parts. Just wanted to know if there is a specific part number for the one I have in the truck. I do not have the time or know who to fix it properly myself.
chevyCUCV
Massachusetts
You certainly have the know how, if you can read the forums, you can read a manual.
Its all just nuts and bolts, at least thats what i tell myself.
Understand the time part though, especially if this is your only vehicle.
GPrez
Mt. Airy, MD
I too wrestled with where to buy one for my M1009. I did alot of research before buying. The pumps are made by Standyne so I looked for a Standyne authorized dealer. The ones on ebay are tempting because of the price, but the reviews on those guys are not so good. Look up the company name on the BBB website and you will see what I mean.
I went with Mid West Fuel Injection (dieselstore.com) and it has been 2-years now and no complaints. They are a little more expensive than some I found, but I think it was worth it.
Someone else mentioned Oregon Fuel Injection above and they were also on my list to try. The only reason I didn't try them was because MWFI was in closer proximity to me shipping wise.
You want to get the Heavy Duty Pump.
JohnnyReb
13
North Georgia Mtns.
ok. i have a question. i have an 86 M1009 that is not getting fuel for some reason. you can fill up her fuel filter and all and she will run but after that, she loses all power and will not run at all. would yall think this would result in a bad injector pump? or do yall think its just a clogged fuel tank??
thanks,
johnnyreb
truck1
10
San Anselmo,CA.
Try Santa Rosa Diesel. Authorized Standyne dealer and rebuild station.Around 600$ to rebuild your stock pump with 1 year warranty. They are located in Santa Rosa ,CA. Better than a Ebay unknown who built it pump.Been to their shop- very clean and all techs trained by Standyne. Good luck.They wanted 1100$ installed to do a 6.2 pump.
WARWAG
thanks,
johnnyreb
Sounds like a dirty fuel filter to me. Change it.
Warthog
232
OKC, OK
Not many items to check in a CUCV fuel system.
Starting from the back.
1 - filter sock in the tank
2 - lift pump on the engine
3 - fuel filter
4 - injector pump
5 - fuel cutoff on the IP
6 - fuse for the IP cutoff
7 - injectors
8 - rubber hoses along the way
The tech manuals do have a step-by-step troubleshooting for the fuel system.
First thing I would do is check the fuel delivery to the fuel filter to see if the lift pump is working.
You may be sucking air thru a bad rubber hose.
det rebel
east texas
best way i have found is pull the hose that comes form the fuel pump on the side of the block going to the fuel filter and spin the engine over and see if fuel sprays out of it and not just trickles or slowly runs out it should have a good solid stream
Warthog
232
OKC, OK
From the TM 9-2320-289-20 manual page 2-40
det rebel
east texas
i normally dont have the TM in my back pocked and i didnt even know what it said, i was just giving my experience working on trucks and equipment.
