seano11
- 103
- 43
- Edmonton Canada
Well I orderd a new poppet valve and installed it today but its still leaking from the exhaust port of the poppet valve anyone have any idea what might cause it to leak ?
I replaced the poppet valve for this reason that when In neutral the air was leaking out the exhaust port on the poppet valve but when the truck is in reverse it doesn't leakIf the seal on the sprag piston is bad(2 way seal), the air couldl flow past and out the exhaust.
Why did you replace your poppet valve?
Sorry That is what I ment when the sprag is in forwards it leaks but not in reverse? how hard is it to change this seal?Unless the air cut off mwo is installed the sprag can not go into neutral, when you shift into reverse the poppet valve shifts the sprag to reverse, as SOON as you shift out of reverse, the other poppet valves shifts the sprag to forward
I know you just spent money on a new poppet but why not just install a 3-way so you could have gotten a 2wd option. I was having multiple issues...plugged supply air to poppet, fixed that, then leaking air from the exhaust, removed poppet and flipped over the rubber diaphrams and got my front drive working sometimes......bypass poppet and installed a 3-way valve and I haven't had any more troubles at all.[/QUOTE
I installed a shut off on the main airline going to the poppet valve isn't that how you get the 4wd option
Untill you to forget to manually flip to forward when you were in reverse, or forget to put in reverse after being in forward, things WILL breakI know you just spent money on a new poppet but why not just install a 3-way so you could have gotten a 2wd option. I was having multiple issues...plugged supply air to poppet, fixed that, then leaking air from the exhaust, removed poppet and flipped over the rubber diaphrams and got my front drive working sometimes......bypass poppet and installed a 3-way valve and I haven't had any more troubles at all.
The air shut off will put the sprag in nutural, as well as a shut off, the air switch HAS to allow the air pressure in the shift cylinder to dump, or the sprag will Stay in the last direction shifted to., this is why the deuce air switch is used for the mwo mod.I know you just spent money on a new poppet but why not just install a 3-way so you could have gotten a 2wd option. I was having multiple issues...plugged supply air to poppet, fixed that, then leaking air from the exhaust, removed poppet and flipped over the rubber diaphrams and got my front drive working sometimes......bypass poppet and installed a 3-way valve and I haven't had any more troubles at all.[/QUOTE
This is the KEY, a lot of air valves do not vent, just shut off, your set up is what is done when another trans is installed, though lever activating air switches could be set up to have the stick activate themI agree Ron about tearing up my tcase, I rarely shift to 4wd and am very cautious as to what gear I'm in when I do...as far as staying locked in....as long as the 3-way valve vents both ports when blocked(2wd) you are good to go.
Sean are you having trouble with front wheel drive or are you just trying to fix a leak?
So is it ok for me to have just the main air valve shut off ? or does it need to vent?This is the KEY, a lot of air valves do not vent, just shut off
HAS to ventSo is it ok for me to have just the main air valve shut off ? or does it need to vent?
Second 275 dollars for a new tranny valve from eastern surplus does this seem like alot ?
