- 14,640
- 4,820
- Buchanan, GA
At Zout's yesterday. But that's just the kettle calling the pot black.
Picked up a bobber today. The drive from Macon to Atlanta was pretty uneventful. Started heading up the hills at Fulton industrial and Thornton rd on I-20 and she started slipping the clutch. I babied it the rest of the way home. It got baaaad the last 10 miles. But I made it home. I noticed the fording plug in the transmission when I picked it up but I didn't think to pull it. Wish I would have now. I pulled the plug at home and drained a half to one quart of engine oil. Drove it around the block just now, it seems like it's getting a little better. I'm considering making up a pipe with a tee and valve in the bottom to allow me fill up the housing with a couple quarts of solvent so I can drain it back up as well. Got a copper crush washer leaking on the rear passenger wheel cyl. And I've gotta figure out the lighting issue. I rigged up a flasher system for it to get it home. Also the rear axle needs to be moved back 4" or so to center it in the wheel well.
Anyhow, I'm working on the CAMO NORTH location. Good thing I can sleep in these trucks, I think I'm at the limit of vehicles here.
