Ironhorse
- 0
- 16
- Central DE
Don't know, first I have to get it to run. It cranks, but doesn't fire. I know I have power to the distributor. I'm going to check the plugs when I get a deeper deep well socket.Does it still pump?
Fight fires in DETROITWhy would a fire truck need a gun ring?
Probably doesn't but I'm curious, what prompted you to ask that question?Why would a fire truck need a gun ring?
Pics:Since it has a REB KIT, I would be interesting if it was taken apart, for a look see because it is not available anymore, maybe someone could see how simple it would be to do the parts and Reintroduce the kit.
Frame and undercarriage look good. Fuel tank is completely rotten, pulled it today. Most of the compartment doors are rusted through next to the hinge but repairable. The hose reel compartment floors will need replacing but one of the doors is laying in the bed. The foam tank is missing. Also, the left front fender is damaged, recently from the looks of it.Congratulations for saving a nice truck! It looks very complete and other than the faded paint also quite solid. What is the sheet metal like (ok, there is a dent in the back running board...) and the frame/undercarriage?
Every M-series truck that uses that cab (the M44, M809, and M39 series trucks) has a leg mount by the passenger door.The leg mount on the passengers side door.
