Cummins 5.9L in a Deuce?
ODdave
41
lansing michigan
Ok, But he is looking for things the stock engine isnt capable of. Hp exceeding 200 isnt gonna happen in the muti, and if it dose, well........it isnt gonna do it long.
OD_Coyote
58
North Bend, WA
If you are going with a 6BT Cummins I would lean toward a variant that does not need a computer for simplicity. I have owned 6BT powered Dodge pickup trucks since 1992 and I like the simplicity of the 12V (no computer). I currently have a 2001 Dodge (24 valve engine with 208K miles) and its still running strong with the original VP44 fuel pump (which is the weak link on the 24 valve motors). Just for the record below is the link to an article on Diesel Power about gent that has 1.4 million miles on his 24 valve Cummins powered Dodge.
2001 Dodge Ram 3500 - Cummins Diesel Engine - Diesel Power Magazine
If I had to replace my LDT I would consider a Cummins, but there would have to be a window in the side of the block for me to go that route.
Ditch Baby
Palm Bay FL
you can put a p-pump from a 12v on a 24v making it all mechanical.
watch out for the 54 blocks on the 24v. prone to cracking.
also, the 5.9 weighs a significant amount less then the multi. ~800lbs lighter.
429
Berkeley Springs, WV
I wouldn't hesitate putting a 6BT into my bobber if I needed a new engine in it. If I had the liquid cash to do it now, I'd probably do it soon.
Lay aside that the 6BT is much ligher than the LDT and comes stock with more HP and torque than the LDT. The biggest draw to moving to the 6BT is parts availability and easy modification for extracting serious horsepower and torque out of it.
Ditch Baby
Palm Bay FL
They weigh more than 800 lbs. The 4.2 in my land cruiser weighs about 800 pounds.
http://www.dieseltruckresource.com/dev/much-does-5-9-cummins-weigh-t243446.html
re-read that.... i said about 800 pounds lighter.
http://www.steelsoldiers.com/deuce-modification-hot-rodding/14801-ldt-weight-vs-6bt-weight.html
weight of a cummins - Dodge Cummins Diesel Forum
53 Block, Not 54
fat fingered that one on the phone... my truck has the 53 block, 145k on it, beat the dog piss out of it and so far no issues.
