M936 recovery
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
I have the correct feet for that tow bar if you didn't get the right ones. That one uses 1 and 1/8th inch pins, not the 1" like a medium.
Ferroequinologist
Resident railroad expert
742
Liberty Hill, SC
Congrats guys! awesome looking wrecker! I tried to use mine last night and the hard line going to the hoist motor blew a leak. On a side note the D600 WVO collection truck looks shiny new!
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
It's the timing cover, not the block (thank god). I'm wondering what would have caused it to bulge from the inside enough to crack the timing cover and break the little cover, yet the motor runs great.
indy4x4fab
Banned
1,711
41
indy, indiana
I'm pretty sure he is looking for options OTHER than replacing the motor block.
nsn 2835012712510 heres the number for the cover.
http://test.steelsoldiers.com/upload/939/TM9-2320-272-24P-1.pdf
page 78 part number 12. It can be replaced, It's going to be a he!! of a female dog to replace.
Looks like your hookers tops coming off (meaning the hood).
73m819
325
gainesville, ga.
From the tm 2320-260-34-1 (same motor)
Measure shim(s) (12) as a pack with micrometer. Add or subtract shim(s) (12) from pack to provide
a clearance of 0.001-0.005 in. (0.0254-0.127 mm) for engines with camshaft thrust plate or
0.008-0.013 in. (0.2032-0.3302 mm) for engines with camshaft outboard bearing support
this suggest that if the WRONG clearance (with/without thurst plate) could cause this
mdmorganwife
14
Forsyth Ga
Planned, but didn't know it at the time. I'll explain, we knew we didn't want one with super singles because most sit with flats for long periods at a time and knowing we would probably be driving it back we didn't want to chance it. So, unknowingly we were wanting a M936.:doghead::gimp2: <----looks like doghead is humping gimpy.
1 Patriot-of-many
86
Zimmerman MN
$6,216.10 after everything said and done. After reading through the T.M. we were even happier that we went with M936 instead of the A1 or A2.
HOLY CRAP! Good steal. I paid $4900 for a M35A3. You two are my hero's!!!!! Congrats all around from me. ( by the way the way if that's your photo in your icon you're hot and he's **** lucky!!!! No disrespect intended married man of 24 years). Unreal to me. 6K for a wrecker!!!!!! **** **** ****!
mdmorgan
AM3 U.S. Navy
1,085
102
Forsyth, Ga.
Ok, this is everything that was on the truck, except the two big boom legs they are way heavy.
