- 456
- 0
- 16
- Eustis, Florida
Oh and I need a Box for the boom control and the cover plats.
Not quite the same, the one shown is a m819, with the cummins motor, a bit heavier then your m246a1, the m819 has a longer nose because of the cummins, other then that SAME, the -10 in the back shows what is in the BII and where it goes, the m246a1 and the m819 have the same BII, so if you can not find what you are looking for in the 211-10, try the 260-10Also This truck is a Mack truck; however, I was shown a picture that is shown bellow of this same truck with the cummings. The front grill is way different then mine, why is this. Mine is flat straight across unlike the picture were the cummings mimics the duece. I was told this truck was a 1963.
You mean where the HYD controls go, how about a pic of the area it is supposed to go, If it is, should not be to hard to make, or find a m62/m246 that is being parted, (everything on the m246 crane body is the same as a m62 except the boom length)Oh and I need a Box for the boom control and the cover plats.
Read post #22, the front nose is longer on the 819 because of the cumminsSo no one really answered about the front of the truck being different
