SMOKEWAGON66
21
California
Well, this weekend I began my preparations to sand-blast and prime the whole truck. I took the bed off and set it to the side to be blasted away from the truck so I can do the frame and axles/back of the cab un-hindered. Still have to remove all the lights, grilled, and cover the glass with steel tape. Im going to seal the cab from the inside as best I can and all openings in engine, trans, seals, breathers, etc. Im renting a 180CFM diesel screw compressor and an industrial blaster/ supplied air breather and I will be using medium grit coal slag...pics forthcoming :beer:
bguy193
Farmersville,IL
Replaced a bad fuel tank, bad fuel pump, installed a new fuel sender while I had the tank off, and finished off with a new set of fuel filters. Now my wallet is gasping for air. I hope for a good recovery.
steelandcanvas
85
Southwestern Idaho
I tinkered around all week after work on the Deuce. I installed an interior armor light in the cab, and re-installed the gauge panel for my boost and pyro. The boost gauge was operational for the event this weekend, but the pyro was not. Installing the pyro pre-turbo is a little more work than a post-turbo installation. This week I'm going to see what my toe-in/out is, front tires are cupping on the outsides. My wallet isn't so bad, I've had these items either previously installed or on the shelf.
Rubenk
NW AR
Ordered all of the filters and hope to do my first oil change when I get to my truck in a few days. As well as new headlight so i'm not running around like a pirate.
islandguydon
783
Michigan
Replaced the air cleaner and installed a solargizer, I silicon-ed it to the top of the hard top passenger rear corner and ran the wires down the back of the cab to the battery box, I secured the wires wrapped in the black flexi stuff to the existing 109 box wires with tie straps.
wrath243
Plentywood, MT
I am new to this site but it has helped immensely with the learning curve on my m35a2. I just completed a 1700 mile trip with everything I own in the back of the deuce. It was a long trip but the beast ran great!
