Blinkers don't blink after LED
blue302stang
Flower Mound, Texas
I am deciding to go with LED signals and brake lights, and after installing the front turn signals the blinkers are no longer working. They light up and thats it. I checked the grounds on everything and it all checks out. With the rear LEDs installed and the stock fronts the blinkers worked fine and with the front LEDs that side wouldn't work. Do these trucks require load resistors when going with LEDs to simulate the load?
doghead
4 Star General /Moderator
1,178
Scroll down to the bottom of this page and click on one of the threads that is similar to this one! That's what you would may have found if you searched before posting.
rickf
1,638
Pemberton, N.J.
I have used that feature several times, it is real handy since I can't ever seem to find the right search term.
willy
Martinez, CA 94553
Led lights
The LED do not draw anough for the blinker to work find a blicker that needs a smaller load or increase your load hide a bulb some where.
Willy
Beerslayer
55
Tualatin, Oregon
My m923 flashers did the same thing when I went to LEDs. Stopped flashing. Same thing as in an older Chevy pickup truck. Bulb burns out, not enough load to make the flasher work, stops flashing, just steady light.
Thanks for the tip ^^ on the newer style flasher at Erik's Surplus. I will get one ordered, that's a lot easier than fooling with resistors and hiding bulbs.
