poppop
- 39
- 48
- Brooklet, Ga
Installed the new distributor cap today and she purrs like a kitten hitting on all six cylinders. drove it around for 45 minutes and it still felt bound up. Kept checking the brake drums and none never even got warm. Tire tracks looked like they were scuffing and since the front tires are a lot bigger than the rear I kept shifting the transfer case to no avail. She finally ran hot and I limped back home cooling the radiator with ditch water. Got the operaters manual out again, I had already read it from cover to cover, And checked on the operation of the transfer case. I had missed the de-clutching lever. I had tried to move it but it seemed stuck. Well, maybe it is in a bind because of the different tire sizes. So I tried backing up slowly while pushing on the lever. It seemed to move some but still bound up. I rocked it back and forth and applied more force and it finally moved. She rolls free as a ball now and I drove it another 45 minutes and never overheated. It was the strain it was in that made it overheat. Now it will chug alone in third gear at idle speed and will even run in fourth. I did not drive it fast because it has no brakes and I stayed on my farm roads
It also was very hard to steer and got to where it was real hard to turn left. It was much better with the front axle dis-engaged but it still has a hard spot going left. When i finish the disassembly I will have to check the steering gear to see if it needs work. I am satisfied now that all the drive train and engine are fine so will continue with the disassembly. I alread have the hood, doors, windshield, cab top support frame and lights removed.
