Yet another M38A1 in my sights
wilfreeman
Richburg, SC
I hope to get mine out on the road again this weekend - I need to install some shorter belts, as my generator is vibrating on the motor mount. I also ned to change my temp sender - mine stops at about 90 deg - might be the gauge though. Then I can ride without too many worries!
armytruck63
10
Redlands, CA
The generator on my A1 is shaking too. The crankshaft pulley is a little bent and I think that is causing the problem. Maybe someone bounced it off the frame when they were installing the engine.
