sparky1
- 1
- 0
- becket,ma.
i unplugged the switch in the left rear of the engine.now the glow plugs cycle all the time.this makes hot starts better.
I will do as you say check the contacts of that sensor and of my gp card, batteries are CAT heavy duty and starter is good too, im still of the opinion that my problem is not fuel related as that when i know im in for a long crank on the key, i pop the hood unplug that sensor and she fires straight awayI would suggest cleaning the contacts on that sensor. Pull the glow plug card and clean the contacts on it too. The -20 has a section on how to check that sensor and what Ohms it should spec out at.
A fully warmed up engine should lite off with less than a second of cranking up to an hour or more after shut down in normal outside temperatures. I wonder about the condition of your batteries and starter not allowing it to spin fast enough. Along with the condition of the IP, fuel filter and lift pump. All of those have been checked, replaced, rebuilt, right?
