Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
If the screw is bottomed out you don't need a longer screw, you need to identify where your air leak is and then fix it. Use some carb cleaner and shoot it around the intake manifold. When the engine speed changes you've found your air leak. Don't forget the PVC valve feeds into the intale too.
If it's bottomed to get things to run, you have other issues. Remove the screw, and look for damage to it's tip. If it's damaged, you might try a new one.
If it's flooding at idle, check the fuel pump pressure. I've seen some cases where the return line orifice is too small, and the pump is forcing the needle off the seat.
You could try a different return line port, use wire gauge drills to incrementally open it, or install an aftermatket pressure regulator.
