where does the o ring go on wheel
Coalman
Paxinos Pa
I have a m35a3 and am in the process of fixing a leaky tire. does the o'ring go in the beveled groove between the two halves Just checking as I do not want to have to tear it apart again Thanks
Bob H
159
Huron National Forest, Michigan USA
Since it should be pretty self evident where the o-ring goes, I'll guess that your O-ring doesn't match up the with the groove?
If it's too big, run cold water over it, too small = hot water.
Coalman
Paxinos Pa
I just want to make sure we are both on the same page When the 2 halves come apart there is a beveled groove between them is that where you are meaning ? Sorry for the stupid question but that looks like the only place it can go and the TM does not show Thanks again
Deuce007
North Dakota
This is going to be something that I have to do in the near future so can you tell me whether or not these steps are correct?
1 remove the entire rim with the tire still on it from the axle
2 undo the bolts holding the two haves of the rim together
3 remove the tire and beadlock from the rim
4 take off the old o-ring and wire brush the groove where it used to be
5 coat the new o-ring heavily in lube
6 put the beadlock and tire back on the rim
7 put the rim back together
8 put the rim back on the axle
My main question is what kind of lube do you use in step 5?
76
Western New York
I believe you are missing a critical step between 1/2, deflating the air from the tire. I know this is probably implicit. But for some folks that may reference this, it is very important.
Good luck when you do it. I observed the guys in the shop do mine and I was glad I was watching.
1 Patriot-of-many
84
Zimmerman MN
When you take off all the CTIS stuff it would deflate....(you can't get the lug nut off the hollow stud without removing the elbow, so automatic deflate)
Western New York
I don't think the CTIS holds pressure between the wheel stud and the value (only when testing or adjusting pressure). My understanding was that the pressurized side was between the valve and the wheel stem.
1 Patriot-of-many
84
Zimmerman MN
My mistake. But you're still going to have to take off the CTIS stuff first, deflating the tire if you haven't already. The elbow I was thinking of is to the turret. That would have to be removed to seperate the rims.
