Volfe
- 2
- 0
- Gresham/oregon
Greetings to all
I am new to this forum and I am sure that it has been discussed at one time, but I can't seem to locate anything with a search, so here I go posting my question. I am working on an M35A2, helping the owner rebuild the front differential assembly. I came into the project after everything was replaced, but not fully assembled. I noticed on the BACK of the Wheel Hub that there are what appears to be bolt holes (they are threaded) around the bearing and race, almost like a plate or seal bolts on to protect the inner bearing. Also the seals that are on the spindle look too small to protect and seal the bearings. I have looked through the forums here, tore through TM's on the Deuce and even what I could locate of my ETM's from my military days. No info on if something bolts there or not. I would hate to reassemble the front end, take it for a test run and discover that it is not sealed and now has to be torn down again (apparently it has been sitting for some time) So I am looking for guidance, please help, THANK YOU.
