View attachment 337380 I have figured out (I think) the first two, the other two I am not sure about. The mics were taken apart but the Cobra mic is a confusing circuit board.
Usually there is a ground and a ptt which when connected to ground causes the radio to key. The outgoing audio from the mic goes out one and shares the gnd.
Sometimes there is receive audio, but that isn't needed here
Figure out by using a small jumper to gnd which one causes it to key... Then you only need to find the mic audio out...
Once you get it so you hear something, you will likely need to get some reliable signal audio checks from someone. The mics are different electrically, but may still be useable.
Btw did you see the updated diagrams to hook all this up through the ls-671 speaker?
Http://www.radionerds.com updated to include remote power off also.
