Anyone put a travel trailer on a Deuce or 5 ton?
markmontana
Mesquite, NV/Layton, UT
My idea is to remove the cargo bed and mount a travel trailer directly to the frame rails. Has anyone done this or pursued the idea?
Picture #1 is similar to my idea. Of course I would not go so far behind the rear axle. Maybe a 14' trailer. But this idea is really making my leg twitch…
Pic #2- A toy hauler might be cool, but would be hard to find one for cheapo. They do have the 'Industrial' look. But there are lots of travel trailers out there for under 1k that would paint up nicely.
I've seen some campers that are slid onto the bed- and that is a possibility- but for now I would like to hear what you think about a self contained trailer on the frame.
Link to full size pic: Trucks :: IMG_1162.jpg picture by davev_photobucket - Photobucket
100dollarman
Lucerne Valley, Ca. 92356
Thought about it many times, but never have done it.
Advantage is all facilities are already built in! Would not be too difficult to mount either.
The thing keeping me from doing it so far, is no AC in the cab.... thinking...
Sephirothq
26
Trevorton / PA
If you are going to take it off roading i could see where the frame would twist and flex and the travel trailer might not be able to do it as well.
It could work fine or be a mess
markmontana
Yes, that has been done. The camper on the MB 1017 is/was a Hi-Lo trailer that Bill Caid mounted on his military truck. Works great, and has AC! (the camper on the red truck was not a trailer, just a slide-in camper and no AC).
Very cool- thanks!
Here's my rendition... sorry, not photoshop qualified
phil2968
Lakeland, Florida
Look at the mounting for the M109 box. That box won't flex. To overcome this the box is spring mounted to the frame from the front to the rear. The very last mount is solid. Flex the truck and the frame is allowed to flex while still keeping the box attached to the truck. Something to look into.
markmontana
Right. I looked at the frame of a travel trailer, and they are way smaller than any 2.5 or 5ton. Some flex is built in to trailers, but not enough to be a problem.
doghead
4 Star General /Moderator
1,179
Why not simply load a camper into the cargo bed?.
markmontana
DH- that is a possibility. And I like the campers I have seen. And they can be had CHEAP around here.
But there is a lot more room in the trailers and I could dedicate a truck to it, so the bed and it's weight could go. Also, the holding tanks, drains, etc etc seem to be suited to the "bedless" truck frame set up. Thinking ROOMY.
PsycoBob
11
Auburn, NY
For A/C in the cab, try a genset that'll work while driving & a large portable A/C unit. I've considered planting one above the transmission tunnel in my M109, with the hot-air vent run right out the back of the cab.
FASTNOVA
146
Los Angeles,Ca
I was thinking of doing the same thing, but with a S280. That way it could be removed to allow use of the truck bed.
goldneagle
1,008
Slidell, LA
For A/C I like the ductless units they advertise on TV for the home. It has a small condenser outside and a baseboard type coil inside. SOme are even available as heat pumps. and 2 separate outputs. That type would serve to cool the cab and the M109 box.
3dAngus
101
Perry, Ga.
You would also cut off the storage compartments located at the bottom of most campers.
Gotta have access to those. A dropside would work.
