Iceman3005
- 97
- 28
- Holt, MI
Question: Are the internals (gears and shafts) the same on an air shift verses a manual shift.
I have an '86 M923A1 5ton. I noticed a leak at the back of the Transfer Case, it is dripping from the part that looks like a round Bell Housing just off the rear of the TC. Not sure what this part is called, I have located it in the TM but no real info there. It only drips after operation then dries up. I haven't noticed any operational issue as a result, I just don't like dripping leaks.
Any wisdom on what this part is called and how difficult it would be to address the leak? aside from the windshield this is the only significant leak I have going. I'd say class 3 all others are class 1 if that.
Thank You
Its common courtesy to start your own thread and not hijack someone elses. (its in the rules also.)I have an '86 M923A1 5ton. I noticed a leak at the back of the Transfer Case, it is dripping from the part that looks like a round Bell Housing just off the rear of the TC. Not sure what this part is called, I have located it in the TM but no real info there. It only drips after operation then dries up. I haven't noticed any operational issue as a result, I just don't like dripping leaks.
Thank You
Short response: YES - for the gears......... Trying to find out if the gears inside the main part of the case are the same, I know the front out put shafts are different but what about the parts in the main part of the case???? No point in buying a manual shift case if the parts we need are different.
Thank you very much, yes I did look at TM's but wasn't sure. As for search, I wasn't finding the correct threads might not have been giving correct search words.
I didn't know you used the search button Gerhard. I thought you had the ability to permanently memorize everything you see, read, hear, etc and just pull it out of your head at a moments notice?
....... I thought you had the ability to permanently memorize everything you see, read, hear, etc and just pull it out of your head at a moments notice?
