Lothar
- 661
- 93
- North Arkansas
Just wanted to share some things I've added and will be adding to my truck. This is my first attempt at uploading pictures so I might have to do some experimenting. This M35A3 was purchased from C&C Surplus, it is a 1995 with 13k miles on the odometer. My plan is to make it into a welding truck that I can use in the event my regular work truck breaks down. And I also intend to use it for recovery, camping, and other mountain fun
First off, I had this addition planned long before I bought the truck. I can only take credit for tightening the bolts on these very nice hubsteps from Jesse (thanks Jesse)
Next I tried to come up with a compact stowable boarding ladder.
I bought a Ratpack toolbox that barely fit where the spare used to be. Added some angle iron to its base and bolted it up to some brackets I made.
Haven't completed this next part, it is a pair of mounts with teflon inlays that hold a couple hi-lift jacks. As you can see I have yet to make the tops, or give the jacks a proper coat of paint.
