cscmc1
- 0
- 0
- Central IL
My M1009 had an inop horn when I bought it, so I dug in this evening. I checked the diode, just for fun, and it looked cooked... so out it came. Still no horn, but the relay clicked, so I checked the physical connections. Someone cut both the horn wire and the blackout driving light wire! I'll bet the horn stuck on at one time, and someone was in a hurry to silence it and snipped both wires, as they are near each other.
Got out the soldering iron and heat shrunk tubing, and put everything back together. Blackout light works like a charm but the horn's still just clicking. Time to get out the 12V test lamp, which reveals no power at the horn. There is a connector just ahead of the suppressor that's bolted down near the horn, and lo and behold, there is power getting TO the suppressor, but not through it. Easy peasy -- bypass the suppressor. Hooked it all back up, and I have a horn again.
Moral of the story: try the logical stuff first, and a test lamp (or meter) is your friend. If your horn is inop, and you have power at the fuse block, a good fuse, and a good relay, check for power at the horn itself. You may have a bad suppressor!
