Deuce parts
rwelker
Gratz, Pa
In the next few months I will be getting 5 deuce parts trucks. The axles and transmissions are sold already. I will be parting out everything else. Cab parts; brade packs; gauges; engines and part; front sheet metal; spring seats; beds; air shift transfer cases and anything else. A few of them are -1C engines. I plan on test running all the engines prior to pulling them and will record hrs; oil pressure; operating temps and such. (Not just a 2 minute run but much longer). If the complete engines don't sell then they will be parted down to the "long block". It will be time to obtain your spares. Email me with your wishes as I will be making a list; this is a winter project so it won't happen in the next few weeks. I'm currently setting up a 50x96 building so that has me occupied right now. Thanks all, Rick
OD_Coyote
58
North Bend, WA
If you have any winch trucks you are going to part out, I am looking for the winch drive shaft and the winch control lever, lockout tab and bracket that go in the cab.
Thanks,
Chris
rwelker
Gratz, Pa
Chris, one was a winch truck but I'm not sure what's still there. I know the winch itself is gone. As soon as I get it home or am down at the trucks I'll look and get back to you. Rick
doghead
4 Star General /Moderator
1,179
Pm sent
frankentruck
I could use a fuel gauge, an undamaged tail gate (OD), and a good soft top. That's just for starters.
Steven
OD_Coyote
58
North Bend, WA
Thanks Rick! Also. if you have a left rear mud guard in good condition may be interested in it as well.
dblcamaros
Schuylkill County, Pa.
cargo cover needed
I am in need of a good cargo cover. Do you have any available, if so how much? I can pick up seeing how I am also in Pa.
WillWagner
2,758
Monrovia, Ca.
Dude....the last post is from 2007! The OP hasn't been on SS since April. Check the classifieds.
