I'm so confused.
This has the original 6 cyl 302 not the V8 350 right?
Yes.
I hear you! I have to stop sometimes and sort them out myself. Here's a quick rundown on what I'm working on and what I call it:
M220#1 - original 6 cylinder, 5 speed manual trans, engine is free but compression is almost non-existent, needs valve job, clutch master cylinder locked up, unsure about brakes
M220#2 - original 6 cylinder, 5 speed manual, engine is frozen, put ATF + PB Blaster in cylinders, checking each week, clutch master cylinder locked up, unsure about brakes
Boyce #1 - can't read serial number on frame, chevy 350, 5 speed manual, engine runs nicely, clutch and trans shifting, we've driven this one around a bit, needs brake work
Boyce #2 - M211 serial number on frame, small block (?), this is the chassis with no bed on the back, it's been picked apart pretty good, I've listed the tilt hood and dash for sale in the classifieds
M35A2 - "the truck in the trees" - non-turbo multifuel, 5 speed manual, currently trying to understand the electrical system, has 12V alternator and "series/parallel" switch installed, hooked up batteries for first time yesterday and got pretty sparks when I touched the final ground wire to battery post.
