- 3,219
- 3,250
- NORTH (Canada)
Once you unlocked the rim from the top plate all the weight is supported by the winch cable and ratchet mechanism only.What is dangerous about the winch?
The ratchet mechanism only works one direction - you have to dis-engage it to lower the wheel.
If you make a mistake, let go of the tool, slip off or use a 3/4 inch ratchet set that is accidentally set to the wrong direction - BOOM
The winch is "dangerous" in this sense, and also because of its mounting location the operator tends to be very close and may inadvertently have a foot or hand right where the wheel smacks onto the ground.
I am not trying to be safety stooge here - just saying that the spare tire winch is not a particularly safe tire lowering device. You have to take care and be alert when lowering a tire.
