calvin3103
- 0
- 6
- ewa beach HI
Dose any one know what kinda rims these are? and if you know will thay fit on a 5 ton .
As opposed to the square plastic ones?Round metal ones.
can you explain to me what you have to do to make the rims fit for 5 ton, i know the hub hole is larger than the five ton, do the bolts line up? the only thing i can think of if the bolts line up is to weld a insert to slim down the hole to the five ton hub? these rims are on aution soon if i can do the mod myself i can pick them up no one out here has use for this rims out herethey will work on a 5ton but you will have to modify them a bit, open the innter circle up a bit and add a new center, this is what I am doing for wheels for my 5ton, I will take pics and do a write up after I get done
