ODdave
- 41
- 0
- lansing michigan
Use a piece of 2" copper pipe or galv pipe!!
2 in diameter? how dose that fit through a 1.68 in hole?
Anyone know the actual diameter of the hole in the cross pin?
http://www.steelsoldiers.com/deuce/69184-check-your-fuel-pump.htmlWhat type of fuel line do I need for the intank pump and what size?
After reading the entire thread, the only viable option that I saw for a submersible line was the "high temperautre viton rubber tubing" (1/2"ID, 5/8"od, 1/16"wall) from mcmastercarr. Will this work?
I'd do that, but the one that's on my truck now clearly isn't meant to be submersed in diesel fuel, it has turned into an awful spongy material. Looking for the correct hose here.Take the pump out of the tank, remove the hose, take to NAPA (or other parts house of choice), ask them to sell you one just like it. Reverse order to complete repairs.
Then take the "spongy" one down and tell them you want one like that, with the ability to be submersed in diesel.I'd do that, but the one that's on my truck now clearly isn't meant to be submersed in diesel fuel, it has turned into an awful spongy material. Looking for the correct hose here.
