shannondeese
- 16
- 18
- High Springs Fl
"Moderators please bear with me on this. What I am building falls under both trailers and modifying Deuces. "
Now onto the meat and potatoes. I am building a 30 ft trailer to pull behind my Deuce. Well sorta pull. I happen to have an extra set of tandems and thought why not make a trailer that can be hooked to the Deuce and power the axles so in effect the trailer will be able to help when I am off road. So I ran the idea by a friend of mine. He owns High Angle Drive Line. After a few minutes / hours we came up with a plan. He has designed a driveshaft for me with a fuse able link so I won't blow any parts if I bind it up. He also has made a CV that will operate at 80 degrees angle. Far more than I will be turning. So here are the pictures and I'll post more as I build it. I am using 8" tall 2" wide 1/4 inch C channel to build it. so it will be strong enough to hold whatever I put on it.
