Upper Kingpin Bearing/Bushing
MatthewH
Boyne City Mi
So after hoping to get by with just bolting the disc brakes on and repacking the wheel bearings, I found the pass side needed new kingpins, as the tire had a goofy wear pattern to it, and the lower kingpin is loose.
After reading the TM, it calls out for a brass/bronze upper cone, and a lower bearing, however, I remember reading somehwere about subsituting a bearing for the bronze cone.
I have searched, but found only mention of this, no part numbers for the bearing or race. Would it be the same as the lower bearing setup?
Thanks
Matt
WhirlingSun
Narrowsburg, New York
Sweet. Thanks. I just ordered the chevy C30 master.
If I may ask, what machine work has to be done? Can I do it on my 9" lathe?
I see they want you to send them your hub to do the work for an additional cost (plus shipping both ways). Is it something as simple as turning down a diameter?
Also, what if I want locking hubs? Should I purchase those before I do the disk brake kit, or is this a different part altogether?
Sorry, I realized I hijacked your thread... My apologies. I'm a little over-excited about the disk brake idea.
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
If you look at the picture, where the rotor bolts to the hub, a special made flange is welded to a turned down hub. Without that flange you won't be able to do it. The lockouts are the same as it uses the same hub (just modified).
MatthewH
Boyne City Mi
Thanks Tuko, thats what I was looking for.
I guess its up to you. After some thought, I decided to send them in and have Joe machine them, since he has the jigs and has done them before. For $120 an axle plus shipping, I can't do the job my self and be ahead.
MatthewH
Boyne City Mi
So who has done this swap? Everythng seems straight forward, really just looking for a spec on setting the preload of the knuckle with 2 bearings, instead of the bushing/brearing setup that was factory.
Everything I have found says "wing it, you'll know when its right".
IIRC, my '71 CJ5 uses kingpin bushing top and bottom, and it uses 15-17 lbs of pull when preloaded correctly. May have to try that and see how it feels.
Thanks in advance
