Bad day at work
Nonotagain
41
Parkville, MD
Yet another example of why I don't like singled out trucks.:roll:
It works both ways PB.
I've handled a few tractor trailer fires where a tube got sucked into the tire and caught the tire on fire burning the entire load. The trailer was carrying 5000 cases of shoe polish.
I've seen inner duals get wrapped around the axle on tubeless tires requiring hours with a sawzall to remove the remains.
Nothing will replace an observant driver.
doghead
4 Star General /Moderator
1,179
Leaking ctis, long term storage, inflate and drive...
Remember this post when you pick up your GL purchase.
2,464
Agreed Sir! The alert driver is the key in most cases.
However...at least in my experience, we have used bolt cutters, hacksaws, knives and anything else we could find to cut off a bolwn tire on a set of duals and limp on to a truckstop or somewhere to get another tire.
I don't knock anyone who uses singles...it's just not my preference and it normally is much harder to "limp" the truck/trailer to a safe haven. :grin:
F18hornetM
10
Ocean City, Md
4 1/2" grinder with a cut off wheel wheel works awesome. Smokes alot and will use up a couple wheels, but has no trouble with the steel cord. Got the idea from cutting 2 wire hydraulic hose on the road with it.
Ps: road truck had a welder so had electric
Flyingvan911
158
Kansas City, MO
With an inside dual wrapping around the axle on a deuce I would worry about it ripping off the brake line and losing the brakes. The flat tire would then be small potatoes.
goldneagle
1,014
Slidell, LA
That is why god invented spare tires. [thumbzup]
bikeman
501
Ft. Bragg, NC
I think I need to stop by and do a personal inspection... about anything to get me out of class or out of this rhythm for a bit. Look for the M38 running around Fires school tomorrow.
