jw4x4
- 6
- 38
- Dayton, Ohio
Here is how we tested a 939 series NHC 250 oil cooler. Utilized two 4" schedule 40 plugs, one of which was outfitted with a threaded steel valve stem. To get the plugs to seal, we used a rubber gasket from a shower enclosure floor drain in one end and a seal (which had a handy skirt) from a fuel pump module on the other end. It was a bit tricky, but we managed to get it all sealed with a small ratchet strap (bar clamps would have been ideal). It held 15 psi and was submerged in water. The leak was instantly identified- in a solder joint. A new cooler and gaskets/seals/o-rings is on the way.
