If you got no fuel movin to the multifuel
This is for everybody with a Deuce.
One can not hear if the electric lift pump in the tank is working with the air pressure low horn blaring .
If the system has not been "opened" then one may get away with pressurizing the fuel tank with air.
If one touches any part of the engine fuel system on an engine that has always started and run without problems, and you touched it, and now it won't run.
It ain't gonnah run anymore without fuel.
Don't do anything but remove the hex driven pipe plug, yes it is really a pipe plug, forget the TM with the gauge and the Tee, about the middle of the picture there and stick a gauge in it. One should have 7psi or so from the intank lift pump. If you get zero than the engine will not run if one opened up anything, like the secondary filters or fuel lines or something. If it was running good before just give her a njew pump and hose.
My truck was dead for a week because I changed out the secondary filters and she wouldn't run anymore!
I am seeking all my pictures to describe this but I find only a few for now.... Anyone interested and I will take the time to find all the pictures.
Once she is running one can switch off the lift pump, no matter.
