New Deuce owner ?
guns1977
26
AL
Hello, I have a 1970 m35a2 and started out no headlights, tail light or flashers. After going thru the posts here I now have working headlights, tail lights and flashers, but yes here is my question when the light switch is on the running lights position aka head lights and tail lights on my rear blinkers/flashers won't work. I can turn the head lights off and they do. It appears the running lights and turn signals work on the same bulb is this correct for operation? or are they supposed to flash while headlights are on?
Thanks for all the help
eagle4g63
34
North/west Indiana
So what you are saying is in the "service drive" position you have head lights but no blinkers?? but in the "stop light" position they do work??
Sounds like a bad switch......they should work in both positions, how else would you be able to signal your turn when it was dark outside!!
That or you have the wires on the tail lights reversed, the bulb is a double filament bulb, the small or dim filament is for running lights(just to light up the lens at night) and the larger brighter filament is for the brake and blinker.
eagle4g63
34
North/west Indiana
A quick way to tell if the wires are reversed is to turn the light switch to the "service drive" position (far right) and look at the back if the light is lit up have someone step on the brake pedal and see it they get brighter, if nothing than switch the wires on the tail lights.
guns1977
26
AL
I've tried that test last night, they do get brighter, I used the brighter brake lights when I am backing up, stop, look, back, stop, look, back,.... So my problem would probably be in the switch?
Thanks
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
RED, it should be on the air pack.
GUNS, I had a similar problem and it was a bad ground on the flasher unit. The flasher box is on the firewall under the hood. I have heard of the wire harness going to flasher controller going bad too. Might want to turn on the hazards and move the wires around slowly to check.
