An SS'r dragging a monstertruck by it's tail
Bob H
160
Huron National Forest, Michigan USA
Here's a pic af a Deuce I used to own,
I'm guessing it's Marv aka dragonwagon unless he sold it ( it was on Craigs list a while ago.)
I wasn't there but I heard " that Arny truck just walked away with it"
I was hoping for a video.
flyxpl
9
Chatham IL
The army truck was at a disadvantage the way the strap is hooked up the monster truck would lift the rear wheels of the deuce upwards giving the deuce less traction and pulling down on the monster trucks rear wheels giving it more traction .
pegasus55
-1
Eaton, Ohio
I noticed the height difference too; definitely an edge for the monster truck. I also figured the monster truck to have a considerable horsepower advantage. However the army truck would probably have a significant weight advantage and an obvious edge on gearing as far as putting power to the ground. I think this would've been an interesting contest to see.
73m819
323
gainesville, ga.
By pulling DOWN on the big truck rear, past the axle, you took all the weight off of the front tires, so ALL the horsepower goes to the rear causing spin-out, with the deuce, the engine weight on the front axle, along with the weight transfer from the lift of the tow strap, the deuce would be almost unstoppable
jw4x4
Dayton, Ohio
That monster truck appears to be an old school out-dated ride. Naturally aspirated big block, I'm guessing. Prolly weighs around 11,000 lbs. The deuce has a definite advantage in this contest. More weight, more torque. I would like to see the video, pretty sure the deuce wins this one.
Bighurt
46
Minot, ND
I think the only true competition is a side by side tractor pull, IMO it evens the odds.
The mention of pulling down on the opponent is exactly what excuse the loser will give.
One on one with the same sled, matches driver and machine against a common obstacle.
3dAngus
101
Perry, Ga.
If that monster was built right and had $50k in it like the original it might have gone the other way even regardless of weight, height, etc as you all know. So for what they got out of it I would have just been glad to be there waving a flag and rootin the deuce on regardless of outcome, but thrilled should the deuce put it to shame.
It would just seem to be an overwhelmingly patriotic moment. Yeah a video would be worth bookmarking.
Can't put up the link from here but google deuce tractor pull and you'll see a nice clean sled pull on utube. It just goes like the everready bunny.
