jwm3800
- 0
- 0
- Oberlin La
I am bidding on some M35A2's on a gov auction site.What is the max i should bid on one? I live about 50 miles from the trucks. How hard would it be to get one started to drive it home?
I am trying to check out some M35A2's at a gov auction yard and i am going to try to use four heavy duty auto batteries to hook up to trucks to try to crank them before i buy one.Does anyone have any pointers on this?
Two batteries in series should be enough. I use two common Wal Mart batteries in my Deuces & 5 Tons.
Use jumper cables to connect the positive on one battery to the negative on the other battery. Combined that gives you 24 volts.
Then jump the truck using the two terminals that are left.
If the trucks have completely dead or shorted batteries you may need to disconnect them and just run your jumpers to the disconnected cables.
Remember to keep all connections insulated from each other and ground!
Shorting 24 volts can hurt you and damage things.
Depends on how much $$$ you have. When I started buying trucks a few years ago, runners where selling for under $1000.I am bidding on some M35A2's on a gov auction site.What is the max i should bid on one? I live about 50 miles from the trucks. How hard would it be to get one started to drive it home?
