- 1,925
- 30
- 48
- Irmo, South Carolina
I see you have the filter is installed on the return side, vs the suction side where I drew it. Good to know.Here is two different drawings of how you could set it up. The drawings are for a open center system. As you can see, it's built in a loop which is how a open center system has to be set up.
Ty, I think we are describing the same thing: an open center valve (or valves) are needed to create circulation, and must be operated to pressurize the couplings.
I was trying to describe that in my second drawing. The specific detail I am trying to understand is which valve to select for that job.
Would you please reply with a link to the specifications of a valve that you recommend for the purpose? Maybe that will help.
Obviously there are different valves to choose from, and I don't want the valve type (3/3 0r 4/3) to dictate what I can or cannot connect to the system. Does that make sense?
Said differently, I imagine that each implement has it's own dedicated operating valve(s) that install with the implement. The valves on the truck do not operate the implement, they only supply the pressure and return fluid paths.
Clearly I do not have experience with these systems and am seeking some answers that may baffle those that really do know something! Please bear with me as I sort this out.
I can understand that, given the variability of the closed center system. It is good to hear that I won't have that worry when considering implements.Generally, the implement you run doesn't care if it's a closed center or open center system. Most implements will run fine with either system.
Thank you,
Rick
