quickfarms
- 24
- 38
- Orange Junction, CA
What is the history of this truck. Did you get it from gl or a private party? What service has been done to it?
It's a GL truck. It probably needs the fuel filter replaced. I will be doing that after this much needed rain passes through. I haven't gotten around to changing all the filters yet so I guess that's a good place to start.What is the history of this truck. Did you get it from gl or a private party? What service has been done to it?
Mike, if your truck does not downshift when you are driving up a hill, something is wrong. All of my trucks downshift just like you might expect when losing speed headed up a hill. I have never had to manually downshift my trucks. I put it in 1-5 and head out...unless I am doing something off road where I want to control the speed and power of the truck.Man, 45 MPH on an incline? I wish mine did that. I find that these allisons don't really like to downshift on their own up hill. Or at least I don't like how low the RPM's get on inclines. I typically downshift to keep my speed up.
The governor is RPM dependant. Most are set around 2100 or so. Question about the transmission and shifting? Check out this video
[media]http://www.youtube.com/watch?v=leCEmJA0WsI[/media]
Try your fuel filter the rpms will chang and I'm sure shifting will come around with the rpms were they are supose to be . its the cheapes test 27 bucks 10 mimI don't think its the fuel because it shifts down to 4th and stays there, no matter if I manually shift, let off on the pedal, shower down on the pedal. I would think if it was the fuel or air filter it would not idle well. I could be wrong, that is why I posted it up here so I could get some info.
Of the 7 or 8 939 series trucks I have driven, they all downshift on their own with a big BANG! Except for one which is an M923a2 with an 8.3 Cummins. It shifts like a dream. The others all shift like they are trying intentionally to scare you.Bruce, she'll downshift on her own but I don't like when. Probably need to have the shift points looked at.
m915a1[/attach][/attach]danl what truck do you have that has a 400 in it?
