Jet A in a 6.5
doghead
4 Star General /Moderator
1,176
I think you will need to add lubrication.
M35A2-AZ
390
Tonopah, AZ
Jet A will clean your fuel system!! May have to change your filters.
Also I think it is very dry, you may need to add a little oil for the IP pump.
Yarb
Arlington, Virginia
We used to run our tugs and our fuel trucks at the airport on Jet A and never had any issues. They always ran very strong, but then again I don't know anything about what it does to seals or anything else in the engine. The A&P mechanics for the G3 and 4's used to take the sumped fuel that we quality control tested and put it in their volkswagon Jetta diesels! It will def run!
jdknech
Jeffersonville, Indiana
I work for a airline (free Jet-A) and ran jet-A in my 95 Z71 diesel 6.5 for months, and it LOVED it, but i blew the heads (too much boost) and i replaced them with 6.2 heads, and now it runs like S*** on jet-A so a stock 6.5 should have no problem with it, just ALWAYS add lube.. i put lucas in mine, and put 100gl worth of additive per 50gl of fuel..
side note- Jet-A is like race-fuel in my M1009 turboed 6.2 :driver:
Oldvw2
Wake Forest, NC USA
thanks ill think ill put some wmo or even new motor oil in the tank to avoid the color red all together
Don't forget that the DS4 injection pump has an optical sensor that needs to "see" the fuel so having it too dark with waste oil or dyes is not a good thing.
FWIW,
Chad
Recovry4x4
LLM/Member 785
1,807
GA Mountains
FWIW,
Chad
This can't be stressed enough. WMO will blind the optical sensor in short order. My son put 5 gallons of 50/50 in my 94 and it pretty much shut it down. The red dye didn't show any ill effects as far as operability. The standyne red and blue formulas were designed for the DS4 and will do nothing but help.
