Anyone changed the fuel pump filter on NHC250?
ARYankee
33
Benton, AR
Due to recent fuel issues that I originally thought were transmission issues, I've been digging into my TMs on my M923. I noticed that there is a fuel pump filter. It is item #1 in the attached picture. It is in TM 9-2320-272-24-1 pg 474-475. I was curious if anyone has changed this and may have found a part supplier. I didn't see it listed on the 5 Ton Parts Quick Reference nor anywhere else so far.
DerangedMadman
Columbus, OH
Cummins quickserve online will probably be your best bet. I used them to get the gaskets for the air compressor when I changed it. Type your engine serial number in and it will tell you the parts you need.
ARYankee
33
Benton, AR
Wow!! That looks really handy! I never knew about it and I'm sure there are others as well that don't. I wonder if it would be better to put it in the 5 ton wiki or start a separate thread and have it stickied.
builderboy
Emporia Ks.
Just when I thought I had changed every filter on my truck.... Here's one more! Yankee would you keep us posted on how easy it was to get a filter? And maybe some parts numbers.
Thanks !!:beer:
ARYankee
33
Benton, AR
Thanks !!:beer:
Will do!
I just need to find where the motor number is. I looked for a plate and couldn't find one. I did find some numbers stamped in the side of the engine block.
doghead
4 Star General /Moderator
1,184
Look for the metal tag on the accessory drive housing, near where the IP mounts to the engine.
You can add the other info to the wiki.
I know we have discussed these little filters before, for the NHC-250 in the 809 series trucks.
doghead
1,184
Did you google the nsn or part number listed in the -24P?
ARYankee
33
Benton, AR
Now one more filter to change.
That's what I was thinking when I saw that and so that is how this thread came about. It was more like what the F***!!! I'm attempting to track a filter down.
This filter will apply to everything except the M936. If you look at the next page 476 - 477. You have a different filter for the M936. At least that is how I'm reading it in the TM.
M35A2-AZ
404
Tonopah, AZ
ARYankee, Nice find on the M936.
But in my set of TM's it is on page 3-108- 3-111.
same tm number done in June 1998
Thanks!!![thumbzup]
goldneagle
1,128
Slidell, LA
I found the part number for the filter! FP-146483 I also found a supply house that sells it. hdengineparts.com $2.77 each. O-ring Item #: M-154088 SEAL RING Item #: FP-154088 $0.13 each [thumbzup]
ARYankee
33
Benton, AR
Thanks!!! [thumbzup][thumbzup] I'll have to add these to my parts database. Some day I will eventually get it done.
M35A2-AZ
404
Tonopah, AZ
Thanks for the filter part numbers!!!
It looks like in the TM that the M936, M936A1 use the same filter.
goldneagle
1,128
Slidell, LA
I tried to purchase the filter today. Talk about shipping ripoff! They wanted almost $25 for shipping FEDEX ground! This order could have gone First Class Mail -its so light! I guess I will look for another source to purchase from. :-x
ARYankee
33
Benton, AR
Wow!! There is always a catch. Is the shipping the same on a larger quantity? I know I'm waiting for quotes from a few sources that I found when I Googled the NSN.
