Ditto...I'd rather disconnect the system and not need to instead of not disconnecting and wish I had. Too easy to play it safe.
Most welders will put out 25-35 volts max when welding. You should be fine as long as you have a good ground close to where you're welding.If you consider that welding can impose 30, 40, 50 volts across small portions of the truck, that's enough voltage to damage lighting, regulators, gens and alternators. Bottom line depends on where the current flows. Sure, if welding on the frame and you put the ground on frame nearby, no problem, but what if your rod touches the fender. No telling where that current flows or what component gets voltage across it. It's always safer to disconnect battery ground, IMHO. I even disconnect the truck ground from the batteries when I'm using the truck batteries to power the Ready Welder to weld on the truck.
The coiled welding cables is a old welding trick to slightly lower the amperage you're welding with, for when the amps you need is between two settings on the welder.Eddy currents are an issue with coiled welding cables if you are welding near to the welder and hitting the heavy amps... You should lay out all the cable in "S's" or fig 8's rather than loops on top of one another - whether laying in a pile or hung on a hook.
I always disconnect alternator and battery/'ies, I was told to do so many many years ago, but can't remember why. (Something to do with solid state huge-a-ma-flips or something and bad grounds/power surges, eddy currents and depleated Uranium dust, blah de blah.....)
