Navo
- 3
- 18
- Chesapeake, VA
I’m about to lose it.... Before I do, I will explain the issue. I bought the truck about 2 months ago. I’m happy as can be, it’s a great truck.
So one day I noticed the passenger side was slinging grease oil mixture. After reading I see that I need to get in there and replace the seals.
OK, So I break down the front passenger hub etc. I replaced the inner and outer seals. While I was in there I noticed the wheel cylinder was leaking and a brake shoe was cracked. So I replace and fix all of those items. Reassemble everything and think to myself. I'll go ahead and do the driver’s side as well.
The driver side was not leaking and didn’t have any know issues. I get busy on that side and discover that also the wheel cylinder is also leaking. So I replace it etc. No other issues on this side. Put it all back together and mount the wheels.
I go ahead and drive it and no problems! Next morning I see oil running down both inner tires. I thought to myself this was residual from when I bleed the brakes. I go ahead and clean it etc. I was gone half the day and when I returned I see it was still dripping. Again, I’m thinking residual....
3 days later.... I think I have another problem. I went under to look at it more closely. The 4 bolts that attach to the spindle housing. The ones on the very bottom that are aligning the king pins. When I tighten them I see gear oil come from behind the boot...On the driver’s side it the same....
WHAT THE ****!!
Any suggestions? Please!
WHAT THE ****!!
