- 4,045
- 63
- Ponchatoula LA
any one need a set of springs and hangers off a m105 or a 818 cab. i am running out of room but could load a trailer for the big stuff
If they are 8on 6.5 bolt pattern and fit on a M880 rear axle hub, I just raised my hand, Sir!Folks, I have a set of 4 16.5x6.5 rims. Looks to be civilian equivilant to the M880 rims. Was going to put HMMWV tires on them but now getting away from that idea. $20 for the set or trade for chilimac. Not bringing them unless someone commits.
THANKS and YES, please!They will and they are yours G. Shall I leave them here and you can get them the following Monday?
If anyone has any of the following M35A2 items please let me know.
Side boards and troop seats
Seat covers - one spring seat, and bench pass side
Battery gauge
Fuel sending unit
Bridge plate numbers
Thanks,
Mike
You have at least one case (24) Chili Mac coming down FOC.Folks, I have a set of 4 16.5x6.5 rims. Looks to be civilian equivilant to the M880 rims. Was going to put HMMWV tires on them but now getting away from that idea. $20 for the set or trade for chilimac. Not bringing them unless someone commits.
Brian I would like the Cable, 15'Heavy duty snatch blocks, 10 ton pulling, 4 ton lifting - $65
45 ton wrecker snatch block, double pulley - $75
Heavy duty tow cable, 15' long, 1.25" cable with large eyelets on ends - $25
.50 caliber gun case, all aluminum, 7'X2.5'X1.5' - $200 I use one as a tool box in the back of the Deuce. See thread for pics:
http://www.steelsoldiers.com/deuce/53256-some-kind-tool-box.html
