I have been trying to figure out where my drive train noises are coming from so hopefully someone can help. I have pulled out the trany again and I can find nothing wrong with my disc and pressure plate. Both are new. A couple of guys are saying the throw out bearing is bad and I thought the one I put in was new also, but now I am wondering. 3 questions... 1) Should there be any slop in the bearing, side to side or in and out and are they available in any parts stores. 2) This clutch disc does not have the springs around the splined center hub and do the springs absorb bounce or torque againt the drive train. Also is this a proper disc (riveted solid)? 3) While I have the trany out, is there any quick field check methods I can use to check if the trany is bad or worn (bearings and such)? Thanks, Bob
