Truck-Lite Route Clearance Lights Installed
YOUNG GUN
10
Sherwood, Oregon
Hmmm, starting to think I didn't put enough lights on my truck now:roll:.
Haha, my general rule of thumb when I do something to my truck is... If it seems a little excessive, it's should probably be more excessive, cause a little just never seems like its enough !
A while back I hooked up a fire truck stutter-tone air horn...a week later I had 2 hooked up, and now I'm planning on 3:grin:
Blueduce
Dallas, Tx
Great mod, I have been beating the idea of adding some real off road lights to me deuce for months now. Now that I have a hard top I half considered putting them where you did. I have also considered on the front bumper, on the fenders or even making brackets to mount them to the windshield brackets like on newer jeeps.(see pick) My biggest concern is finding the best place to install them but keep them as protected as I can. Knowing my luck with an install like yous I would knock one off with the first branch I found. I do like your chosen location. Do you have any plans to add brush guards around these lights.
YOUNG GUN
10
Sherwood, Oregon
I may add a brush guard at some point, however these specific lights, if not tightened to tight at the pivot will fold over if hit (low speed obviously).
I've tested it out just by pushing on the lense by hand and moving them forward and back, and they will not move on there own from the vibration of normal driving and offroading.
swbradley1
Modertator
1,666
Dayton, OH
Yeah, I'm going to get 4 more to point towards the back of the truck.
They would make great backup lights, just remember in a night convoy you could nuke the guy's eyes behind you.
If they fold up hitting a branch then they would probably make it at Haspin. ;-)
748
Woodstock, GA
I put 8 on mine and I plan on eventually adding 2 more to the front bumper and 2 more to the rear. I didn't go the LED route though because when I was sourcing everything the LED's I could find were very expensive. Did you get a deal and do you mind sharing what you paid? Great looking setup by the way. [thumbzup]
swbradley1
Modertator
1,666
Dayton, OH
I thought this was a great idea until I saw the price for those lights.........
748
Woodstock, GA
Yeah, that is what I found when sourcing lights. LED's are truly awesome, just more than I care to spend.
I got my lights on sale for I think $10/each and then spent about $2/each to put 24 volt bulbs in them. Those 24 volt bulbs aren't as bright as LED's but they are pretty dang bright. Added a little paint and viola, I'm out of pocket with 8 lights for half the price of 1 LED light. Hopefully the price for LED's will continue to come down and I can work them into a future truck. :idea::idea::idea:
sigo
Lieutenant Colonel
386
Leavenworth, KS
Young gun, great looking set up. What's the scoop with that rubber piece between the uprights and the cab? Did you do that just to take up the slack between the pole and the unbolt, or is it there to dampen vibrations and squeaking? What material did you use?
