dstang97
- 30
- 48
- Clover, SC
Had some problems with the deuce today. Went to get a vin check and when I came home I was testing all of the lights. Then I hit the high beam switch sparks started flying by the switch then the wires above the steering wheel started to catch fire. I did some good damage. I was able to put it out with my hand, but kept relighting. I was finally able to disconnect the batteries. So i guess when it stops raining I will have to do some more research. It looks like the wires chaffed against a metal clamp the supports the wire to the column. Has this happened to anyone here.
Also any connections to NOS in cab wiring harnesses????
