Asmoday
- 0
- 16
- Los Angeles, CA
Hello All,
Ok...after many hours of reading different posts on swapping a 700R4 into the M1009 I have just a few specific questions relative to my situation.
I currently own a 1987 K5 gaser with the factory 700R4/NP208 in it. I was already planning on swapping parts from it onto my M1009. I find myself wanting an overdrive gear more and more on the freeways here in SoCal because people are running my a** over...
I'm aware that I will need the specific TV cable, Diesel specific TV Bracket(anyone have one?), flywheel, governor and diesel torque converter and do the lock up mod(hydraulic or electric) for the swap.
What I would like to know is...
1. Can I pull the gaser trans and transfer case out as a unit and drop it right into the M1009 with no other mods other than what's known above?
2. Will I need to move the cross-member and should I use the gaser cross-member or does it not make a difference?
3. I believe that the stock M1009 drive shafts should fit ...correct?
4. I have read that some years of the 700R4 were problematic and had weakness issues with the more desirable units being built from '87 on. Better valve bodies, etc. Is this correct? I have a later in the year build '87 700R4 so I hope this is true...
5. What is the difference between the earlier and later 700R4's?
6. It seems that the spline count on the 87 700R4 is 30. Correct?
I know that I will have to have the 700R4 gone through anyway as it has been occasionally slipping for years in the gaser but I think if it will swap into my M1009 without much work it's a less expensive way to go than a GV unit?
Are there s certain upgrades that should definitely be thrown in on the rebuild?
All answers and opinions are much appreciated...!
Thanks!
Adam
Thanks!
Adam
