- 1,367
- 949
- State College, PA
My M1009 became increasingly hard to start when the glow plugs were needed to be on. Finally one morning it wouldn't start at all. Batteries are good, glow plugs are good and my GP card is good, relay made normal noise when closing.
After getting a volt meter from my work truck, found that I had nominal
12 volts at the top terminal of the relay and next to nothing at the bottom terminal. So the glow plugs were not getting any voltage and thus the reason for no start.
I went to NAPA and purchased a ST85 relay. Installed it and the truck starts fine.
Wondering why the relay failed, I opened the relay it and found out why.
Simple reason is dirt. One of the contacts had accumulated a considerable amount of dirt and this was causing enough resistance under high current load to have a low voltage at the lower terminal.
I cleaned (wire brushed) all the contacting surfaces inside reassembled the unit and tested for proper operation.
Once again we can see why high current loads require clean and tight contacts.
Attached are pictures for your enjoyment.
Karl
Karl
