dc9137
- 0
- 0
- Rogers, AR
Anybody ever use this stuff? The guy who works there says its made by pennzoil and he uses it in his diesel all the time. $22 for 2 gal. Just curious
True. If it were made by Penzoil I would run away. Their paraffin based oil gummed up the 4 cylinder Fords so bad back in the '80s that it starved the bearings for oil. Personally, I'll stick with Rotella since it's so widely used by the diesel owners and just as economical.Supertech is made by Warren.
Well played sir! The oil that is delivered to the base I work at is Rotella 15W40 and if it's good enough for them, I'll run the same. I've never heard anything bad about it and I run Diesel Oil in my older Non Catalytic Converter equipped vehicles as well as I've read it has higher sulfer content which used to be the "antiwear" additive of choice and the newer alternatives are not quite up the the job. That means everything in my yard with the exception of my Trans Am as he still has Cats.Given I get Shell Rotella 15W40 by the 55 gal drum,it only runs me about $11.68 a gal after tax,i'll stick with that.
What ever happened to Cheveron stuff, such as Delo 400 and such. I have used that oil in everthing from a Ford pinto, to a Pacific 100 ton Belly Dump Truck with out any issues at all.
Citgo actually produces the 15W40.
http://msds.walmartstores.com/clien...3-9d27-f04a7bed65ca&action=MSDS&subformat=NAM
Always search for the MSDS on a product when you question the source.
The guy who works there may be right, or he may be wrong. Just because he works in a store doesn't mean he knows who makes the products.
