Need help with 2.5 ton rockwells
Broncofever
nj
Well I got the front ripped apart and have some questions.
I DON'T have any thrust washers on the axle shafts(u joint style). Do I need them? And if so, where can I get them????
On the red barn website they sell a cork gasket set for the key way shaft on the front axle, whats it for and do i need them? Didn't have none in there when I took it apart.
And to stop gear oil from coming out the axle shaft, do I need to get some of these axle tube retainer with the better seals to stop oil for coming out? [URL]http://www.customoff-road.com/index.php?id=custom_products Or just get the stock seals?
[/URL]
My tie rod bar has a slight bend to it, is that ok or do I need it to be straight?
thanks guys....
Woodsplinter
Phoenix/AZ
Most parts can be found at military suppliers such as Erik's military, Saturn Surplus, Memphis Equipment, TNJ Murray, Boyce Equipment and many others.
Google "military surplus" ", "military suppliers", etc.
phil2968
Lakeland, Florida
Roll the tie rod till the bend is down and place a bottle jack under the bend and jack it straight. Reset your toe in to less than a 1/4' or less at the center of the tire. I run dead straight on my tires.
