M923 front hub dilemna
Westex
El Paso, TX
I have an M923, 1997 vintage, with a caterpillar engine and allison push button tranny. It was an experimental truck I bought from wehring. Coming back from a trip recently, my front left hub was WAY hot. We have pulled it apart, and although I think the hub bearings are greased, the spline shaft coming through the spindle seems to be oiled, but not from the differential oil. There is some kind of oiler on the actual hub, and that's as far as I've gotten with this project. Anybody have a clue as to whether or not this is some kind of combination oil/grease front lube set up?
Westex
El Paso, TX
Would like to see some pics.
Will work on that today; I realize it's kind of a nebulous question, but I think I have a weird front axle, or I'm not seeing how the inner bearings that support the front drive shaft is lubricated. I'm 99% sure it is NOT from the differential oil. Pics to follow.
Westex
El Paso, TX
12-01-2012 download 017.jpg12-01-2012 download 018.jpg12-01-2012 download 019.jpg
Above pics show my question(s). First pic where the arrows are: what is the bolt cap on the hub between the arrows. Is this for adding grease? The hole goes straight down between 2 seals on the axle spindle. Second pic with the small arrows has us bewildered. What is the hole for?
The third pic shows what great fun I'm having with this project. Any special grease needed for that universal joint? Stuart.
FASTNOVA
138
Los Angeles,Ca
That would be if the truck had CTIS, air would exit from that hole on the spindle to the hub on the 1st picture then out to the wheel. It is the same as my truck. Use high temp bearing grease.
M35A2-AZ
390
Tonopah, AZ
That is my think also on the CTIS.
Westex
El Paso, TX
That makes sense; I'm seeing it now. Since I have removed the CTIS system, can't I just do away with the 2 inner seals that seal off that CTIS hole in pic #2?
